16-Port Gigabit Ethernet Easy Smart PoE+ Switch with 1 Dedicated SFP port (180W)
GS116EP
gs116ep-shadow-front-left
gs116ep-shadow-front-tipoff
gs116ep-shadow-front-right
gs116ep-shadow-rear-left
gs116ep-shadow-rear-tipoff
gs116ep-shadow-rear-right
  • 16 Ports
Port Types
  • 16 x 10/100/1000 RJ45 Copper Ports (Auto Uplink)
  • 15 x PoE+ 802.3at Ports
  • 1 x SFP fiber ports
PoE Budget
  • Up to 180W
15 x Gigabit Ethernet ports with PoE+ with 1 SFP Fiber port Plug-and-play with fundamental network management features QoS and VLAN management Fanless and silent Desktop or wall-mount
Download GS116EP Datasheet
GS116EP
16 Ports • 15 PoE+ • 1G • up to 180 W
  • 16 Ports
Port Types
PoE Budget
  • Up to 180W
GIGABIT ETHERNET AND FIBER
15 ports provide Gigabit Ethernet connectivity to your devices and 1 SFP fiber port for long distance connections
EASY POE CONTROLS
Manage PoE prioritization, PoE power limit per port, PoE scheduling and more for advanced control over all PoE-powered devices
VERSATILE MOUNTING OPTIONS
Place your switch on your desktop or mount it to your wall with the hardware provided in the box. Silent operation makes this switch perfect for noise-sensitive environments
VLANS
FANLESS DESIGN
ENERGY EFFICIENT
Product Datasheet
Dimensions (W x D x H)
286 x 101 x 27 mm (11.3 x 4.0 x 1.1 in)
Weight
0.83kg (1.83 lb)
Speed
1G
Number of Ports
16
Number of PoE+ Ports
15
Number of SFP Ports
1
PoE Power per Port
Up to 30
PoE Budget
Up to 180W
Yes
Jumbo Frame Support
10,000 bytes
MAC Table Size
8K
Packet buffer size
4.1MB
IEEE 802.1p QoS
Yes
Max Power Consumption
198.7W
Operating Temperature
0-40°C (32°F - 104°F)
MTBF (hours)
784,742 hours (89 years)
FCC Class
Class B
Warranty :
Support :
High Resolution Images
Low Resolution Images
DatasheetInstallation GuideUser Manual
