8-Port Gigabit Ethernet PoE+ Easy Smart Essentials Switch (62W)
GS308EP
  • 8 Ports
Port Types
  • 8 x 10/100/1000 RJ45 Copper Ports (Auto Uplink)
  • 8 x PoE+ 802.3at Ports
PoE Budget
  • 62W
The NETGEAR 8-Port Gigabit Ethernet PoE+ Easy Smart Switch delivers essential business networking features and powers PoE+ devices like VoIP phones, IP cameras, and more.
Download GS308EP Datasheet
GS308EP
8 Ports • 8 PoE+ • 1G • up to 62 W
  • 8 Ports
Port Types
PoE Budget
  • 62W
Gigabit Ethernet
8 ports provide up to 1000 Mbps of dedicated, non-blocking bandwidth each.
PoE+ Support
8 PoE+ ports provide a total of 62W of power so you can power and connect your devices with a single wire.
Advanced PoE Controls
Manage PoE prioritization, PoE power limit per port, and more for simple control over all PoE-powered devices.
Non-Blocking Switching
10Gbps (10/100/1000 Mbps) line rate fabric ensures congestion-free connectivity to your devices.
Fanless Design
Silent operation makes this switch perfect for noise-sensitive environments.
Versatile Mounting Options
Install your switch on your desktop, or mount it to your wall or rack with the hardware provided in the box.
Product Datasheet
Dimensions (W x D x H)
158 x 101 x 27 mm (6.2 x 4.0 x 1.1 in)
Weight
0.49 kg (1.08 lb)
Speed
Gigabit
Total PoE+ Ports
8
Total PoE+ Budget
62W
Uninterrupted PoE
Yes
Bandwidth
16Gbps
Max Mac Entries
4K
Buffer Size
192KB
Energy Efficient Ethernet (IEEE 802.3az)
Yes
Priority Queuing
WRR
Jumbo Frame Support
9,216 bytes
Warranty :
Support :
High Resolution Image
Low Resolution Image
We're Always Here to Help
Visit my.netgear.com
