8-Port Gigabit Ethernet Easy Smart Essentials PoE Switch (123W)
GS308EPP
1 / 7
  • 8 Ports
Port Types
  • 8 x 10/100/1000 RJ45 Copper Ports (Auto Uplink)
  • 8 x PoE+ 802.3at Ports
PoE Budget
  • 123W
Easy to manage, fundamental network features at an affordable cost for SMBs. GS308EPP offers 123W total power budget to power devices PoE devices such as VoIP phones, IP cameras, wireless access points, etc.
Download GS308EPP Datasheet
GS308EPP
8 Ports • 8 PoE+ • 1G • up to 123 W
  • 8 Ports
Port Types
PoE Budget
  • 123W
Gigabit Ethernet
8 ports provide up to 1000 Mbps of dedicated, non-blocking bandwidth each.
PoE+ Support
8 PoE+ ports provide a total of 123W of power so you can power and connect your devices with a single wire.
Advanced PoE Controls
Manage PoE prioritization, PoE power limit per port, and more for simple control over all PoE-powered devices.
Non-Blocking Switching
10Gbps (10/100/1000 Mbps) line rate fabric ensures congestion-free connectivity to your devices.
Fanless Design
Silent operation makes this switch perfect for noise-sensitive environments.
Versatile Mounting Options
Install your switch on your desktop, or mount it to your wall or rack with the hardware provided in the box.
Product Datasheet
​Dimensions (W x D x H)
158 x 101 x 27 mm (6.2 x 4.0 x 1.1 in)
​Weight
0.49 kg (1.08 lb)
Speed
Gigabit
Total PoE+ Ports
8
Total PoE+ Budget
123W
Uninterrupted PoE
Yes
Bandwidth
16Gbps
Max Mac Entries
4K
Buffer Size
192KB
Energy Efficient Ethernet (IEEE 802.3az)
Yes
Priority Queuing
WRR
Jumbo Frame Support
9,216 bytes
Warranty :
Support :
High Resolution Image
Low Resolution Image
We're Always Here to Help
Visit my.netgear.com
