16-Port High-Power PoE+ Gigabit Ethernet Easy Smart Essentials Switch (231W) with 1 SFP Port
GS316EPP
1 / 8
  • 16 Ports
Port Types
  • 16 x 10/100/1000 RJ45 Copper Ports (Auto Uplink)
  • 15 x PoE+ 802.3at Ports
  • 1 x SFP port
PoE Budget
  • 180W
The NETGEAR 16-Port High-Power PoE+ Gigabit Ethernet Easy Smart Switch delivers essential business networking features and powers PoE+ devices like VoIP phones, IP cameras, and more.
Download GS316EPP Datasheet
GS316EPP
16 Ports • 15 PoE+ • 1G • up to 231 W
  • 16 Ports
Port Types
  • 1 x SFP port
PoE Budget
  • 180W
Gigabit Ethernet
16 ports provide up to 1000 Mbps of dedicated, non-blocking bandwidth each
PoE+ Support
15 PoE+ ports provide a total of 231W of power so you can power and connect your devices with a single wire.
Advanced PoE Controls
Manage PoE prioritization, PoE power limit per port, PoE scheduling and more for simple control over all PoE-powered devices
Non-Blocking Switching
10Gbps (10/100/1000 Mbps) line rate fabric ensures congestion-free connectivity to your devices.
Fanless Design
Versatile Mounting Options
Install your switch on your desktop or mount it to your wall with the hardware provided in the box
Product Datasheet
Dimensions (W x D x H)
286 x 102 x 27 mm (11.26 x 4.02 x 1.06 in)
Weight
0.88 kg (1.95 lb)
Speed
Gigabit
Total PoE+ Ports
15
Total PoE+ Budget
180W
Uninterrupted PoE
Yes
Bandwidth
32Gbps
Max Mac Entries
4K
Buffer Size
192KB
Energy Efficient Ethernet (IEEE 802.3az)
Yes
Priority Queuing
WRR
Jumbo Frame Support
10,000 bytes
Warranty
Support
NETGEAR Support offers a customizable support experience based on your operational needs:
High Resolution Images
Low Resolution Images
Become a Partner
We're Always Here to Help
Visit my.netgear.com
