8x1G PoE+ 220W and 2xSFP+ Managed Switch
GSM4210PX
1 / 12
  • 10 Ports
Port Types
  • 8 x 1G PoE+
  • 2 x SFP+
PoE Budget
  • 8 PoE+ (30W/port)
  • 220W Budget
Switching engineered for 1G AV over IP with versatile mounting options for under a table or behind a display. Pre-configured for out of the box functionality!
Download GSM4210PX Datasheet
GSM4210PX
10 Ports • 8 PoE+ • 1G • up to 220 W
  • 10 Ports
Port Types
  • 8 x 1G PoE+
  • 2 x SFP+
PoE Budget
  • 8 PoE+ (30W/port)
  • 220W Budget
m4250 pro av dt 1 v2 tcm148 139485
POWERFUL AV SWITCHES
MADE SIMPLE
FAST, EASY
CONFIGURATION
FOR AV PROS
m4250-pro-av-dt-4
FOCUS ON THE EVENT
NOT FAN NOISE
m4250-pro-av-dt-5
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
Product Specifications
Dimensions (WxDxH):
210x 140 x 40 mm
Weight:
967g (2.13lb)
Primary Port Speed:
1 Gigabit
Number of Ports:
10 (8x 1G PoE+, 2x SFP+)
PoE Ports / Budget:
8 PoE+ (30W/port), 220W Budget
IGMP Support:
Enhanced (NETGEAR IGMP Plus™)
Jumbo Frame Support:
Yes, up to 12kb
AVB Support:
Yes. Electronic license required, activation key sent via email (AVB4210PX-10000S)
Acoustics:
Fanless or 3dB at 25ºC
Power Consumption:
With PoE: 257.9W/880.47Btu/hr
Without PoE:
18.14W/61.93Btu/hr
Standby without any port connection:
9.51W/32.47Btu/hr
Warranty :
Support :
M4250-8G2XF-PoE+ (GSM4210PX)
Power Adapter
Power cord(s)
Console USB Type-C cable
Flat brackets for desktop or wall mounting
Installation guide
High Resolution Image
Low Resolution Image
User ManualInstallation Guide
