48x1G PoE+ (236W base, up to 1,440W) and 4xSFP+ Managed Switch
GSM4352
1 / 11
  • 52 Ports
Port Types
  • 48 x 1G PoE+
  • 4 x 10G SFP+
PoE Budget
  • 48 PoE+ (30W/port)
  • 236W base
  • up to 1
  • 440W budget
  • 48 Gigabit PoE+ ports with 4 10GBASE-X SFP+ uplinks
  • 550W internal power supply providing 236W of PoE budget
  • 2 slots for modular power supplies (1+1 redundancy and/or EPS share)
  • Any APS350Wv1, APS600Wv2, APS920Wv1, or APS2000Wv1 can be used
  • The PoE budget can reach 1,440W, the redundant PoE budget can also reach 1,440W
  • NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
Download GSM4352 Datasheet
GSM4352
52 Ports • 48 PoE+ • 1G • up to 1 • 440 W
  • 52 Ports
Port Types
  • 48 x 1G PoE+
  • 4 x 10G SFP+
PoE Budget
  • 236W base
  • up to 1
  • 440W budget
POWER AND
THROUGHPUT
Fast, Easy Configuration
for AV Pros
A streamlined interface using certified profiles with settings for any AV or broadcast application assigned to ports with just a few clicks.
m4250-pro-av-dt-5
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
M4350 Max performance GSM4352 desktop tcm148 150693
MAXIMIZE
PERFORMANCE
WITH PRO WIFI
ACCESS POINTS
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
Product Specifications
M4350-48G4XF (GSM4352):
1
Power cord(s):
1
Console USB Type-C cable:
1
Rack-mounting standard bracket set:
1
Set of longer brackets for recessed mounting:
1
Rubber footpads for tabletop installation:
4
Installation guide:
1
Width:
440mm
Depth:
400mm
Height:
43.2mm
Weight:
7.19kg (15.85lb)
Primary Port Speed:
1 Gigabit
Number of Ports:
52 (48 x 1G PoE+, 4 x 10G SFP+)
PoE Ports / Budget:
48 PoE+ (30W/port), 236W Base, up to 1,440W Budget
IGMP Support:
Enhanced (NETGEAR IGMP Plus™)
Jumbo Frame Support:
Yes, up to 12kb
AVB Support:
Yes, included
Acoustics:
Quiet Mode 33dB@25ºC
Power Consumption:
With PoE: 348W/1186.68Btu/ hr
Without PoE: 99W/310.86Btu/ hr
Standby without any port connection: 48.5W/152.29Btu/ hr
PSU Compatible Models:
APS350Wv1
APS600Wv2
APS920Wv1
APS2000Wv1
NETGEAR Engage Controller:
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
Warranty :
​This product is backed by NETGEAR limited lifetime hardware warranty.​
Support :
High Resolution Images
Low Resolution Images
M4350 Datasheet M4350 Brochure M4350 Product Brief
