16x 2.5G PoE++ (530W base, up to 1,130W) incl. 8x Neutrik etherCON and 4x SFP28 25G Managed Switch
MSM4320
New
1 / 13
  • 20
Port Types
  • 16x 2.5G PoE++ incl. 8x Neutrik etherCON
  • 4x 25G SFP28 uplinks
PoE Budget
  • 1130W total when the redundant PoE budget remains 530W (1+1)
  • Two internal 800W power supplies providing 530W of redundant base PoE budget
  • Switch ships with one APM414V interface card with 4x 25G SFP28 ports
  • Optional APM414C Interface Card with 4x 10G RJ-45 ports
  • Optional APM414SD Interface Card with 2x Neutrik opticalCON QUAD connectors for 4x MMF transceivers
  • Optional APM414LD Interface Card with 2x Neutrik opticalCON QUAD connectors for 4x SMF transceivers
  • 2x Neutrik powerCON connectors and C14 male power cord adapters for standard IEC 320 C13 leads
  • NETGEAR IGMP Plus™, NETGEAR AV OS™, and NETGEAR Engage™ Controller speed up AV installations
  • SMPTE ST 2110 Grandmaster Clock and Boundary Clock for AES67 and ST2059-2 applications
  • Multi-colour LED on each physical port reflecting the profile colour in the NETGEAR AV OS™ and Engage Controller
Download MSM4320 Datasheet
MSM4320
20-Port | 16x 2.5G PoE++ incl. 8x Neutrik etherCON | 4x 25G SFP28 | MSM4320
  • 20
Port Types
PoE Budget
View all accessories
Power and Throughput
Edge to core flexible platform, from 1 Gigabit to 100 Gigabit, good for projects of all sizes.
m4350 simplified desktop
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
Fast, Easy Configuration
for AV Pros
A streamlined interface using certified profiles with settings for any AV or broadcast application assigned to ports with just a few clicks.
m4250 pro av dt 5 tcm148 139377
Designed For AV Over IP Right out of the Box
With built-in NETGEAR IGMP Plus™, there's little-to-no setup required for flawless audio and video delivery. Enable multicasting right out of the box.
m4250 pro av dt 8 tcm148 139376
PRO AV RESOURCES
RESOURCES
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
M4350-16M4V (MSM4320) Technical Specifications
1
Power Cord (Standard AC to C13)
1
Neutrik powerCON connectors and C14 male power cord adapters for standard IEC 320 C13 cords
2
Console USB Type-C cable
1
Rack-mounting standard bracket set
1
Set of longer brackets for recessed mounting
1
4
Installation guide
1
Width
440mm
Depth
432mm
Height
43.2mm
Weight
7.85kg (17.31lb)
Primary Port Speed
2.5 Gigabit
Number of Ports
20 (16 x 2.5G PoE++ incl. 8x Neutrik etherCON, and 4x 25G SFP28)
IGMP Support
Enhanced (NETGEAR IGMP Plus™)
Jumbo Frame Support
Yes, up to 12kb
AVB Support
Yes, included.
Acoustics
Quiet Mode 35.6dB@25ºC
Power Consumption
With max PoE: 1359.8W/4,639.64Btu/hr
Without PoE: 109.6W/373.96Btu/hr
Standby w/o any port connection
50.6W/170.60Btu/hr
PSU Compatible Models
Internal only
Internal PSUs
2 internal 800W PSUs with PowerCON connectors
Compatible Interface Cards
APM414SD (2x Neutrik opticalCON QUAD for 4x MMF Transceivers)
APM414LD (2x Neutrik opticalCON QUAD for 4x SMF Transceivers)
APM414V (4x Standard 25G SFP28 ports) ships with the switch
APM414C (4x Standard 10G RJ5 ports)
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
Warranty :
Support :
Pro AV Information
M4350-16M4V Support
AV Resource Center
High Resolution Images
Low Resolution Images
Visio Stencils
