24x2.5G, 4x10G/Multi-gig PoE++ (522W base, up to 2,520W) and 4xSFP28 25G Managed Switch
MSM4332
CMS_Tech_Specs_Image-MSM4332_P_Shadow.Front_Tipoff
1 / 9
  • 32 Ports
Port Types
  • 24 x 2.5G PoE++
  • 4 x 10G/Multi-Gig PoE++
  • 4 x 25G SFP28
PoE Budget
  • 522W Base | up to 2520W Budget
  • 24 2.5G and 4 10G/Multi-gig PoE++ ports with 4 25GBASE-X SFP28 uplinks.
  • 800W internal power supply providing 522W of PoE budget.
  • 2 slots for modular power supplies (1+1 redundancy and/or EPS share).
  • Any APS600Wv3, APS1200Wv2, or APS2000Wv2 can be used.
  • The PoE budget can reach 2,520W, the redundant PoE budget can reach 1,972W.
  • Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover.
  • Layer 3 feature set includes static, policy-based, and dynamic routing.
  • NETGEAR IGMP Plus™, NETGEAR AV OS, and Engage Controller speed up AV installations.
  • SMPTE ST 2110 Grand Master Clock and Boundary Clock for AES67 and ST2059-2 applications.
  • Multi-colour LED on each physical port reflecting the profile colour in the NETGEAR AV OS™ and Engage Controller.
Download MSM4332 Datasheet
MSM4332
32 Ports • 28 PoE++ • 25G • up to 2 • 520 W
  • 32 Ports
Port Types
  • 24 x 2.5G PoE++
  • 4 x 25G SFP28
PoE Budget
View all accessories
Power and Throughput
Edge to core flexible platform, from 1 Gigabit to 100 Gigabit, good for projects of all sizes.
m4350 simplified desktop
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
Fast, Easy Configuration
for AV Pros
A streamlined interface using certified profiles with settings for any AV or broadcast application assigned to ports with just a few clicks.
m4250 pro av dt 5 tcm148 139377
Designed For AV Over IP Right out of the Box
With built-in NETGEAR IGMP Plus™, there's little-to-no setup required for flawless audio and video delivery. Enable multicasting right out of the box.
m4350 msm4310 max performance desktop tcm148 168473
Maximize Performancewith Pro WiFiAccess Points
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
LEARN MORE
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
M4350-24M4X4V Technical Specifications
M4350-24M4X4V(MSM4332)1
Power cord(s)1
Console USB Type-C cable1
Rack-mounting standard bracket set1
Set of longer brackets for recessed mounting1
Rubber footpads for tabletop installation4
Installation guide1
Width440mm
Depth400mm
Height43.2mm
Weight7.38Kg (16.26lb)
Primary Port Speed2.5 Gigabit
Number of Ports32 (24 x 2.5G PoE++, 4 x 10G/Multi-Gig PoE++, 4 x 25G SFP28)
Total PoE++ Ports28
Total PoE++ Budget522W Base, up to 2,520W Budget
IGMP SupportEnhanced (NETGEAR IGMP Plus™)
Jumbo Frame SupportYes, up to 12kb
AVB SupportYes, included.
AcousticsQuiet Mode 34.8dB@25ºC
Power Consumption
With max PoE: 2,845W/9,702.59Btu/hr
Without PoE: 123.4W/420.95Btu/hr
Standby without any port connection: 53W/180.94Btu/hr
PSU Compatible Models
APS600Wv3
APS1200Wv2
APS2000Wv2
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
Warranty :
​This product is backed by NETGEAR limited lifetime hardware warranty.​
Support :
High Resolution Images
Low Resolution Images
