8x10G/Multi-Gig and 8xSFP+ (XSM4316) Managed Switch
XSM4316
1 / 13
  • 16 Ports
Port Types
  • 8 x 10G/Multi-Gig
  • 8 x 10G SFP+
PoE Budget
  • N/A
  • 8 10G/Multi-Gig ports and 8 10GBASE-X SFP+ ports
  • 240W internal power supply
  • Half-width form factor enables one or two switches in a single rack space for redundant top-of-rack
  • Layer 3 feature set includes static, policy-based and dynamic routing
  • NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
Download XSM4316 Datasheet
XSM4316
16 Ports • 10G/Multigig
  • 16 Ports
Port Types
  • 8 x 10G/Multi-Gig
  • 8 x 10G SFP+
PoE Budget
  • N/A
POWER AND
THROUGHPUT
m4350 simplified desktop
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
Fast, Easy Configuration
for AV Pros
A streamlined interface using certified profiles with settings for any AV or broadcast application assigned to ports with just a few clicks.
m4250-pro-av-dt-5
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
M4350 Max performance GSM4352 desktop tcm148 150693
MAXIMIZE
PERFORMANCE
WITH PRO WIFI
ACCESS POINTS
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
m4250 pro av dt 8 tcm148 139376
PRO AV RESOURCES
RESOURCES
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
Product Specifications
M4350-8X8F (XSM4316)1
Power cord(s)1
Console USB Type-C cable1
Switch rack-mounting standard bracket set1
Switch set of longer brackets for recessed mounting1
Switch pairing kit for two half-width M4350 switches in a single rack space2
Rubber footpads for tabletop installation4
Installation guide1
Width220mm
Depth400mm
Height43.2mm
Weight4.05kg (8.93lb)
Primary Port Speed10 Gigabit / Multi-Gig
Number of Ports16 (8 x 10G/Multi-Gig, 8 x 10G SFP+)
PoE Ports / BudgetN/A
IGMP SupportEnhanced (NETGEAR IGMP Plus™)
Jumbo Frame SupportYes, up to 12kb
AVB SupportYes, included
AcousticsQuiet Mode 34.4dB@25ºC
Power Consumption
81.1W/254.65Btu/hr
Standby without any port connection: 30.5W/95.77Btu/hr
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
Warranty :
​This product is backed by NETGEAR limited lifetime hardware warranty.​
Support :
High Resolution Images
Low Resolution Images
