12x10G/Multi-Gig and 12xSFP+ (XSM4324) Managed Switch
XSM4324
1 / 11
  • 24 Ports
Port Types
  • 12 x 10G/Multi-Gig
  • 12 x 10G SFP+
PoE Budget
  • N/A
  • 12 10G/Multi-Gig ports, and 12 10GBASE-X SFP+ ports
  • 240W internal power supply
  • Half-width form factor enables one or two switches in a single rack space for redundant top-of-rack
  • NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
Download XSM4324 Datasheet
XSM4324
24 Ports • 10G/Multigig
  • 24 Ports
Port Types
  • 12 x 10G SFP+
PoE Budget
  • N/A
POWER AND
THROUGHPUT
m4350 simplified desktop
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
Fast, Easy Configuration
for AV Pros
A streamlined interface using certified profiles with settings for any AV or broadcast application assigned to ports with just a few clicks.
m4250-pro-av-dt-5
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
XSM4324 MAXIMIZE PERFORMANCE
MAXIMIZE PERFORMANCE WITH PRO WIFI ACCESS POINTS
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
LEARN MORE
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
M4350-XSM4324 Technical Specifications
M4350-12X12F (XSM4324)
1
Power cord(s)
1
Console USB Type-C cable
1
Switch rack-mounting standard bracket set
1
Switch set of longer brackets for recessed mounting
1
Switch pairing kit for two half-width M4350 switches in a single rack space
2
4
Installation guide
1
Width
220mm
Depth
400mm
Height
43.2mm
Weight
4.3kg (9.48lb)
Primary Port Speed
10 Gigabit / Multi-Gig
Number of Ports
24 (12 x 10G/Multi-Gig, 12 x 10G SFP+)
PoE Ports / Budget
N/A
IGMP Support
Enhanced (NETGEAR IGMP Plus™)
Jumbo Frame Support
Yes, up to 12kb
AVB Support
Yes, included
Acoustics
Quiet Mode 34.3dB@25ºC
Power Consumption
95.8W/300.81Btu/hr
Standby without any port connection: 34W/106.76Btu/hr
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
Pro AV Information
M4350-12X12F Support
AV Resource Center
High Resolution Images
Low Resolution Images
