5-Port Gigabit Ethernet Unmanaged Switch
GS105
GS105_productcarousel_hero_image
1 / 8
  • 5 Ports
Port Types
  • 5 x 10/100/1000Mbps Gigibit Ethernet
PoE Budget
  • n/a
Get networks up and running with plug-and-play unmanaged switches. Set it and forget it, energy-efficient switches are built like tanks and last for decades.
Download GS105 Datasheet
GS105
5 Ports • 1G
  • 5 Ports
Port Types
PoE Budget
  • n/a
ETHERNET PORT CONFIGURATION
5 Gigabit ports
PLUG-AND-PLAY
FULL PERFORMANCE
Product Datasheet
Carousel Swimlane Image 1 tcm148 112508
Plug-and-Play
No configuration necessary - perfect for SOHO small-medium businesses and home office / entertainment.
Carousel Swimlane Image 2 tcm148 112509
Smart Energy Savings
Energy efficient Ethernet (IEEE 802.3az) cuts energy consumption during little or no activity on active ports.
Carousel Swimlane Image 3 tcm148 112510
Built to Last
Switches are housed in a solid, compact metal case and rigorously tested for reliability.
Carousel Swimlane Image 4 tcm148 112511
Designed for Zero-Noise Operation
Passively cooled fanless design to protect your business environment.
Plug-and-Play
Built to Last
Dimensions (WxDxH) @mm :
94 mm x 100 mm x 27 mm
Weight (kg) :
0.261 kg
Speed :
Number of Ports :
5
PoE ports :
n/a
Total PoE Budget :
n/a
Loop Detection :
n/a
Short cable power saving :
n/a
Energy Efficient Ethernet Support (IEEE 802.3az):
Yes
Jumbo Frame Support :
Yes
Queue WRR Ratio :
1:2:4:8
MAC Table Size :
2K
Packet buffer size :
128KB
IEEE 802.1p QoS :
Yes
Max Power Consumption :
2.7W
Operating Temperature :
50°C
MTBF (hours) :
3,197,945 hours
FCC Class :
B
Warranty :
Support :
GS105v5/GS108v4/GS116v2 Datasheet
Installation Guide
We're Always Here to Help
Visit my.netgear.com
