8-Port Gigabit Ethernet Unmanaged Switch
GS108
1 / 9
Get networks up and running with plug-and-play unmanaged switches. Set it and forget it, energy-efficient switches are built like tanks and last for decades.
GS108
8 Ports • 1G
ETHERNET PORT CONFIGURATION
8 Gigabit ports
PLUG-AND-PLAY
FULL PERFORMANCE
Product Datasheet
Carousel Swimlane Image 1 tcm148 113050
Plug-and-Play
No configuration necessary - perfect for SOHO small-medium businesses and home office / entertainment
Carousel Swimlane Image 2 tcm148 113055
Smart Energy Savings
Energy efficient Ethernet (IEEE 802.3az) cuts energy consumption during little or no activity on active ports.
Carousel Swimlane Image 3 tcm148 113051
Built to Last:
Switches are housed in a solid, compact metal case and rigorously tested for reliability.
Carousel Swimlane Image 4 tcm148 113052
Designed for Zero-Noise Operation
Passively cooled fanless design to protect your business environment
Weight :
0.47 kg (1.04 lb)
Dimensions :
158 x 102 x 27 mm (6.2 x 4.0 x 1.1 in)
Product name :
NETGEAR 8-Port Gigabit Ethernet Unmanaged Switch (GS108)
Speed :
10/100/1000Mbps Gigibit Ethernet
Number of Ports :
8
PoE ports :
n/a
Total PoE Budget :
n/a
Loop Detection :
n/a
Short cable power saving :
n/a
Energy Efficient Ethernet Support (IEEE 802.3az):
Yes
Jumbo Frame Support :
Up to 9K packet size
Queue WRR Ratio :
1:2:4:8
MAC Table Size :
4K
Packet buffer size :
192KB
IEEE 802.1p QoS :
Yes
Operating Temperature :
32° to 104°F (0° to 40°C)
FCC Class :
B
Energy Efficient Ethernet support :
Yes - Compliant with IEEE802.3az Energy Efficient Ethernet mode
Jumbo frame support :
9,216 bytes
Warranty :
Limited lifetime support**
Technical Support (online, phone) :
90 days free from date of purchase
Extended ProSupport Support and Warranty Available
​Support
High Resolution Image
Low Resolution Image
Installation Guide
We're Always Here to Help
Visit my.netgear.com
