16-Port Gigabit Ethernet Unmanaged Switch
GS116v3
CMS_Carousel_Image-GS116v3_wShadow_Right
  • 16 Ports
Port Types
  • 16 x 10/100/1000Mbps Gigibit Ethernet
PoE Budget
  • n/a
• 16 x Gigabit Ethernet ports • Energy Efficient Ethernet for maximum power savings • Fanless and silent • Desktop or wall-mount
Download GS116v3 Datasheet
GS116v3
16 Ports • 1G
  • 16 Ports
Port Types
PoE Budget
  • n/a
Reliable Performance
Superior network performance at non-blocking rate delivers true gigabit speed with no compromise
Energy Efficient
Plug-and-Play
No software to install. No configuration needed. Zero maintenance required
Silent Operation
Versatile Mounting Options
Install your switch on your desktop or mount it to your wall with the hardware provided in the box
Metal Case
Durable and rugged case for long-lasting performance
Product Datasheet
Dimensions (WxDxH)
286 x 102 x 27 mm (11.3 x 4 x 1.1 in)
Weight
0.89kg (3.3lb)
Speed
Number of Ports
16
PoE ports
n/a
Total PoE Budget
n/a
Loop Detection
n/a
Short cable power saving
Yes
Yes
Jumbo Frame Support
9KB
Queue WRR Ratio
1:3:5:7:8:10:12:15
MAC Table Size
8K
Packet buffer size
512KB
IEEE 802.1p QoS
Yes
Max Power Consumption
8.1W
Operating Temperature
0 to 50° C
MTBF (hours)
4,160,957 hrs
FCC Class
A
Warranty :
Support :
Low Res Images
High Res Images
Installation GuideDatasheet
