5-Port Gigabit Ethernet Unmanaged PoE+ Essentials Switch with 4-ports PoE+ (83W)
GS305PP
CMS_Tech_Specs_Image-GS305PPv3_wshadow_Left
1 / 7
  • 5 Ports
Port Types
  • 5 x 10/100/1000Mbps Ports (Auto Uplink)
  • 4 x 802.3af PoE Ports
  • 4 x 802.3at PoE+ Ports
PoE Budget
  • Up to 83W Total
5-Port Gigabit Unmanaged switch with 4 PoE+ ports and 83W power budget to power Wireless AP, IP Cameras, IP Phones and more
Download GS305PP Datasheet
GS305PP
5 Ports • 4 PoE+ • 1G • up to 120 W
  • 5 Ports
Port Types
PoE Budget
  • Up to 83W Total
ETHERNET PORT CONFIGURATION
5 Gigabit ports
PLUG-AND-PLAY
FULL PERFORMANCE
Product Datasheet
Carousel Swimlane Image 2 tcm148 113103
Smart Energy Savings
Energy efficient Ethernet (IEEE 802.3az) cuts energy consumption during little or no activity on active ports.
Carousel Swimlane Image 3 tcm148 113104
Built to Last:
Switches are housed in a solid, compact metal case and rigorously tested for reliability.
Carousel Swimlane Image 4 tcm148 113105
PoE Convenience
With Power over Ethernet, use only one cable for both power and connectivity.
Dimensions
158 x 101 x 27 mm (6.2 x 4.0 x 1.1 in)
Weight
0.40 kg (0.88 lb)
Speed
Gigabit
Number of Ports
5
Number of PoE Ports
4 PoE+ ports, up to 30W per port
PoE budget
Up to 83W Total
Yes
Jumbo frame support
9,216 bytes
Queue WRR Ratio
1:3:5:7:8:10:12:15
MAC table size
2k
Packet buffer size
128KB
IEEE 802.1p QoS
Yes
Power Consumption (Max/Standby)
88.89W/2.89W
Operating Temperature
0-40°C (32°F - 104°F)
MTBF (hours)
4,113,947 hrs (469.32 years)
6,189,896 hrs (706.61 years)
FCC Class
Class B
Fans
0
Acoustic Noise Level @25C
Fanless
Warranty
Support:
High Resolution Image
Low Resolution Image
Become a Partner
We're Always Here to Help
Visit my.netgear.com
