NETGEAR Essentials Switches featuring 16 ports of gigabit Ethernet. This switch is plug-and-play requiring no extra setup. It’s durable, energy-efficient and rigorously tested delivering reliable performance. GS316v3 GS316-300NAS GS316-300NAS
Unmanaged Essentials Switch (GS316v3) armor
16-Port Gigabit Ethernet Unmanaged Essentials Switch armor
Looking for  GS316v1 ? Please see the Helpful Links in the Tech Specs for more information.
Join Waitlist
Successfully registered.
PLUG-AND-PLAY
Simple set up with no software to install or configuration needed
FULL PERFORMANCE
FANLESS DESIGN
VERSITILE MOUNTING OPTIONS
Install your switch on your desktop or mount it to your wall with the hardware provided in the box
ENERGY EFFICIENT
gs316v3
gs316v3
  • Dimensions (WxDxH) : 286 x 102 x 27 mm (11.3 x 4.0 x 1.1 in)
  • Weight : 0.89 kg (1.96 lb)
  • Speed : 100 Mbps/1 G
  • Number of Ports : 16
  • Energy Efficient Ethernet Support (IEEE 802.3az) : Yes
  • Jumbo Frame Support : 9 KB
  • MAC Table Size : 8 K
  • Packet buffer size : 512 KB
  • IEEE 802.1p QoS : Yes
  • Max Power Consumption : 8.1 W
  • Operating Temperature : 0-50° C (32° F - 122° F)
  • MTBF (hours) : 4,160,957 hours (475 years)
  • FCC Class : Class A
    • Warranty :  This product is backed by a 3-year Hardware Warranty.
    • Click here for coverage, availability and terms and conditions.
  • Support : ProSUPPORT 24x7 Advanced Technical Support via phone for 90 days (Remote diagnostics performed by our technical experts for prompt resolution of technical issues). ProSUPPORT coverage can be extended by purchasing one, three, or five-year contracts.
