Simplify connectivity with PoE
Power over Ethernet (PoE) is the seamless way to combine power and network connectivity in a single cable. Forget the constraints of traditional power outlets—PoE allows you to connect and power devices effortlessly, whether it’s wireless access points, IP cameras, LED lights, or IoT devices. With NETGEAR PoE solutions, businesses unlock simpler installations, reduced costs, and endless possibilities.
What can you power with PoE?
PoE (15.4W)
IP phones, basic access points, and simple cameras
PoE+ (30W)
High-performance devices, including dual-band APs, security cameras, and conference systems
Ultra60 PoE++ (802.3bt, Type 3) (60W)
LED lighting, large speakers, and digital signage
Ultra90 PoE++ (802.3bt, Type 4) (90W)
AV encoders/decoders, PTZ cameras, WiFi access points
The NETGEAR advantage
Extensive Portfolio
Choose from 50+ PoE models, including switches with up to 1440W budgets.
Flexibility for Every Business
From unmanaged to fully managed switches, for businesses of all sizes.
Future-Proof Innovation
Features like FlexPoE and uninterrupted PoE ensure your investment is ready for tomorrow.
Reliability You Can Trust
Designed to power critical business applications with unmatched uptime and precision.
Power your network with confidence
Simplify your setup, expand your possibilities, and trust NETGEAR to keep your connections strong. Discover how PoE from NETGEAR can elevate your business today.
