Managed Ethernet Switch for AV over IP (GSM4248PX)
GSM4248PX
1 / 14
- 48 Ports
Port Types
- 40 x 1G PoE+
- 8 x SFP+
PoE Budget
- 40 PoE+ (30W/port)
- 960W Budget
GSM4248PX
- 48 Ports
Port Types
- 40 x 1G PoE+
- 8 x SFP+
PoE Budget
- 960W Budget
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
Product Specifications
Dimensions (WxDxH): | 440 x 400 x 43.2 mm |
Weight: | 6.31 kg (13.91lb) |
Primary Port Speed: | 1 Gigabit |
Number of Ports: | 48 (40x 1G PoE+, 8x SFP+) |
PoE Ports / Budget: | 40 PoE+ (30W/port), 960W Budget |
IGMP Support: | Enhanced (NETGEAR IGMP Plus™) |
Jumbo Frame Support: | Yes, up to 12kb |
AVB Support: | Yes. Electronic license required, activation key sent via email (AVB4248PX-10000S). |
Acoustics: | Fanless or 59dB@25ºC |
Power Consumption: | With PoE: 1197W/4086.56Btu/hr |
| | Without PoE: 89.2W/304.53Btu/hr |
| | Standby without any port connection: 74.5W/254.34Btu/hr |
Warranty : | This product is backed by NETGEAR limited lifetime hardware warranty. |
Click here for coverage, availability and terms and conditions. | |
Support : | NETGEAR Support offers a customizable support experience based on your operational needs: |
Sprint support option with 24/5 Technical Support (phone, online) and Advance RMA Replacement | |
Overdrive support option with 24/7 Technical Support (phone, online, 2h SLA) and Next Business Day RMA Replacement | |
Support coverage in one, three, or five year contracts |
| | M4250-40G8XF-PoE+ (GSM4248PX) |
| | Power cord(s) |
| | Console USB Type-C and RJ45-DB9 cables |
| | Rack-mounting standard brackets |
| | Longer brackets for recessed mounting |
| | Rubber footpads for tabletop installation |
| | Installation guide |
