8x10G/Multi-Gig and 8xSFP+ (XSM4316) Managed Switch
XSM4316
- 16 Ports
Port Types
- 8 x 10G/Multi-Gig
- 8 x 10G SFP+
PoE Budget
- N/A
- 8 10G/Multi-Gig ports, and 8 10GBASE-X SFP+ ports
- 240W internal power supply
- Half-width form factor enables one or two switches in a single rack space for redundant top-of-rack
- Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover
- Layer 3 feature set includes static, policy-based, and dynamic routing
- NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
- 16 Ports
Port Types
- 8 x 10G/Multi-Gig
- 8 x 10G SFP+
PoE Budget
- N/A
PRO AV RESOURCES
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
Product Specifications
| M4350-8X8F (XSM4316) | 1 |
| Power cord(s) | 1 |
| Console USB Type-C cable | 1 |
| Switch rack-mounting standard bracket set | 1 |
| Switch set of longer brackets for recessed mounting | 1 |
| Switch pairing kit for two half-width M4350 switches in a single rack space | 2 |
| Rubber footpads for tabletop installation | 4 |
| Installation guide | 1 |
| Width | 220mm |
| Depth | 400mm |
| Height | 43.2mm |
| Weight | 4.05kg (8.93lb) |
| Primary Port Speed | 10 Gigabit / Multi-Gig |
| Number of Ports | 16 (8 x 10G/Multi-Gig, 8 x 10G SFP+) |
| PoE Ports / Budget | N/A |
| IGMP Support | Enhanced (NETGEAR IGMP Plus™) |
| Jumbo Frame Support | Yes, up to 12kb |
| AVB Support | Yes, included |
| Acoustics | Quiet Mode 34.4dB@25ºC |
| Power Consumption | 81.1W/254.65Btu/hr Standby without any port connection: 30.5W/95.77Btu/hr |
| NETGEAR Engage Controller | Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive. |
Warranty : | This product is backed by NETGEAR limited lifetime hardware warranty. |
Click here for coverage, availability and terms and conditions. | |
Support : | NETGEAR Support offers a customizable support experience based on your operational needs: |
Sprint support option with 24/5 Technical Support (phone, online) and Advance RMA Replacement | |
Overdrive support option with 24/7 Technical Support (phone, online, 2h SLA) and Next Business Day RMA Replacement | |
Support coverage in one, three, or five year contracts |
