36x10G/Multi-Gig PoE++ (280W base, up to 1,760W) and 4xSFP28 25G Managed Switch
XSM4340CV
1 / 8
- 40 Ports
Port Types
- 36 x 10G/Multi-Gig PoE++
- 4 x 25G SFP28
PoE Budget
- 36 PoE++ (90W/port)
- 280W Base
- up to 1
- 760W Budget
- 36 10G/Multi-Gig PoE++ ports with 4 25GBASE-X SFP28 uplinks
- 750W internal power supply providing 280W of PoE budget
- 1 slot for modular power supply (1+1 redundancy and/or EPS share)
- Any APS600Wv3, APS1200Wv2, or APS2000Wv2 can be used
- The PoE budget can reach 1,760W, when the redundant PoE budget remains 280W
- Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover
- Layer 3 feature set includes static, policy-based, and dynamic routing
- NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
- NETGEAR ProSAFE® Limited Lifetime Hardware Warranty
- Lifetime Next Business Day Hardware Replacement
- 40 Ports
Port Types
- 4 x 25G SFP28
PoE Budget
- 280W Base
- up to 1
- 760W Budget
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4350-XSM4340CV Technical Specifications
M4350-36X4V (XSM4340CV) | 1 | |
Power cord(s) | 1 | |
Console USB Type-C cable | 1 | |
Rack-mounting standard bracket set | 1 | |
Set of longer brackets for recessed mounting | 1 | |
Rubber footpads for tabletop installation | 4 | |
Installation guide | 1 |
Width | 440mm | |
Depth | 400mm | |
Height | 43.2mm | |
Weight | 7.33kg (16.16lb) | |
Primary Port Speed | 10 Gigabit / Multi-Gig | |
Number of Ports | 40 (36 x 10G/Multi-Gig PoE++, 4 x 25G SFP28) | |
PoE Ports / Budget | 36 PoE++ (90W/port), 280W Base, up to 1,760W Budget | |
IGMP Support | Enhanced (NETGEAR IGMP Plus™) | |
Jumbo Frame Support | Yes, up to 12kb | |
AVB Support | Yes, included | |
Acoustics | Quiet Mode 32.1dB@25ºC | |
Power Consumption | With PoE: 454W/1548.14Btu/hr Without PoE: 148W/464.72Btu/hr Standby without any port connection: 59.3W/186.2Btu/hr | |
PSU Compatible Models | APS600Wv3 APS1200Wv2 APS2000Wv2 |
NETGEAR Engage Controller | Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive. |
This product is backed by NETGEAR limited lifetime hardware warranty. | |
Click here for coverage, availability and terms and conditions. |
NETGEAR Support offers a customizable support experience based on your operational needs: | ||
Support coverage in one, three, or five year contracts | ||
Pro AV Information | Learn More | |
M4350-36X4V Support | Learn More | |
AV Resource Center | Learn More |
