8-Port Gigabit Ethernet Unmanaged Switch with 1 dedicated 10G/Multi-Gig Port
PLUG-AND-PLAY
Simple set up with no software to install or configuration needed
FULL PERFORMANCE
SILENT OPERATION
ENERGY EFFICIENT
Designed to optimize power usage lowering its cost to operate
METAL CASE
Durable and rugged case for long-lasting performance
VERSATILE MOUNTING OPTIONS
Supports desktop and wall placement with included wall-mount kit
NETGEAR GS108MX Unmanaged Switch | |
Power adapter (varies by region) | |
Wall-mount kit | |
Installation guide | |
Rubber feet |
Width | 236mm (9.3in) |
Depth | 101mm (4.0in) |
Height | 27mm (1.1in) |
Weight | 1.26lb (0.58kg) |
Gigabit copper ports | 8 |
Uplink port | 1 x 10G/Multi-Gig Port |
Max MAC entries | 16K |
Buffer size | 768Kbit or 0.75Mbit |
EEE | Yes |
Internal/External Power Supply/Adapter | External Power Adapter |
Max power consumption (worst case. all ports used, line-rate traffic) | 5.8W |
Fans | 0 |
Acoustic Noise Level @25C | 0 dBA |
Operating Temperature | 0° to 40° C (32° to 104°F) |
MTBF | 3,514,690 hrs (401 yrs) |
Warranty : | This product is backed by NETGEAR limited lifetime hardware warranty. |
Click here for coverage, availability and terms and conditions. | |
Support : | NETGEAR Support offers a customizable support experience based on your operational needs: |
Support coverage in one, three, or five year contracts |
