5-Port Gigabit Ethernet Unmanaged PoE+ Essentials Switch with 4-ports PoE+ (83W)
ETHERNET PORT CONFIGURATION
5 Gigabit ports
PLUG-AND-PLAY
FULL PERFORMANCE
POWER-OVER-ETHERNET
4 PoE ports with 83W total power budget to power wireless AP, IP Cameras, IP Phones and much more
PoE POWER AUTO-BALANCE AND ALLOCATION
NETGEAR's unique PoE technology automatically balances the PoE power at the most granular level on each port, depending on the device needs.
SILENT OPERATION
ENERGY EFFICIENT
Designed to optimize power usage lowering its cost to operate.
Metal Case
Durable and Rugged
VERSATILE MOUNTING OPTIONS
Supports desktop and wall placement. Includes wall mount kit in the box
STANDARDS-BASED DESIGN
Ensure interoperability with any standards-based PDs
Smart Energy Savings
Energy efficient Ethernet (IEEE 802.3az) cuts energy consumption during little or no activity on active ports.
Built to Last:
Switches are housed in a solid, compact metal case and rigorously tested for reliability.
PoE Convenience
With Power over Ethernet, use only one cable for both power and connectivity.
Dimensions | 158 x 101 x 27 mm (6.2 x 4.0 x 1.1 in) |
Weight | 0.40 kg (0.88 lb) |
Speed | Gigabit |
Number of Ports | 5 |
Number of PoE Ports | 4 PoE+ ports, up to 30W per port |
PoE budget | Up to 83W Total |
Energy Efficient Ethernet Support (IEEE 802.3az) | Yes |
Jumbo frame support | 9,216 bytes |
Queue WRR Ratio | 1:3:5:7:8:10:12:15 |
MAC table size | 2k |
Packet buffer size | 128KB |
IEEE 802.1p QoS | Yes |
Power Consumption (Max/Standby) | 88.89W/2.89W |
Operating Temperature | 0-40°C (32°F - 104°F) |
MTBF (hours) | 4,113,947 hrs (469.32 years) 6,189,896 hrs (706.61 years) |
FCC Class | Class B |
Fans | 0 |
Acoustic Noise Level @25C | Fanless |
Warranty | This product is backed by NETGEAR limited lifetime hardware warranty. |
| | Click here for coverage, availability and terms and conditions. |
Support: | NETGEAR Support offers a customizable support experience based on your operational needs: |
Support coverage in one, three, or five year contracts |
