8-Port Gigabit Ethernet Unmanaged Essentials Switch
GS308
1 / 9
- 8 Ports
Port Types
- 8 x 10/100/1000Mbps Ports (Auto Uplink)
PoE Budget
- n/a
GS308
- 8 Ports
Port Types
PoE Budget
- n/a
Ethernet Port Configuration
8 Gigabit ports
Plug-and-play
Full Performance
Silent Operation
Energy Efficient
Designed to optimize power usage lowering its cost to operate.
Metal Case
Durable and Rugged
Versatile Mounting Options
Supports desktop and wall placement, and includes all mounting hardware in the box
Standards-based Design
Ensure interoperability with any standards-based PDs
Plug-and-play
Automatic connectivity to your router or modem of 4 or 7 additional wired connections. No need for an IT expert!
Mounting flexibility
Small and silent desktop form factor for quiet operation – Adapts to your needs and configuration in any environment
Energy efficient
Switches automatically adjust power consumption according to the link status and cable length.
Dimensions | 158 x 101 x 29mm (6.2 x 4.0 x 1.1in) |
Weight | 0.39 kg (0.86 lb) |
Model Description | NETGEAR 8-Port Gigabit Ethernet Unmanaged Essentials Switch (GS308v3) |
Speed | Gigabit |
Number of Ports | 8 |
Connector Type | Metal |
Switch Housing | Metal |
LEDs | Power, Link/Activity |
Short cable power saving | Yes |
Energy Efficient Ethernet Support (IEEE 802.3az) | Yes |
Jumbo frame support | 9,216 bytes |
MAC Table Size | 8K |
Packet buffer size | 192k |
DC Power Adapter | 12V / 0.5A |
Max Power Consumption (Watts) | 3.04W |
Acoustic Noise Level @ 25° C (dBA) | 0 dBA (Fanless) |
Operating Temperature | 0° to 40°C (32° to 104°F) |
MTBF (@ 25° C) | 3,711,898 hours |
Electromagnetic compliance (A or B) | Class B |
Form Factor | Desktop or wall-mountable |
Warranty | This product is backed by NETGEAR limited lifetime hardware warranty. |
| Click here for coverage, availability and terms and conditions. |
Support | NETGEAR Support offers a customizable support experience based on your operational needs: |
| Support coverage in one, three, or five year contracts |
