AV Line M4250-40G8XF-PoE+ (GSM4248PX)
40x1G PoE+ 960W and 8xSFP+ Managed Switch
Switching engineered for 1G AV over IP with rear-facing ports ensuring a clean integration in AV racks. Pre-configured for out of the box functionality!
POWERFUL AV SWITCHES
MADE SIMPLE
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
FAST, EASY
CONFIGURATION
FOR AV PROS
FOCUS ON THE EVENT
NOT FAN NOISE
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
REFINED DESIGN
PROVIDES MOUNTING
FLEXIBILITY
COMPARE M4250 SERIES SWITCHES
PRO AV FAMILY COMPARISON
M4250 SWITCH SERIES |
M4350 SWITCH SERIES |
M4500 SWITCH SERIES |
USE CASE |
USE CASE Access/Edge |
USE CASE Core/Access/Edge |
SWITCH STACKING |
SWITCH STACKING No |
SWITCH STACKING Yes |
SWITCH STACKING No (MLAG) |
PoE CAPABLE |
PoE CAPABLE Yes |
PoE CAPABLE Yes |
PoE CAPABLE No |
PORT SPEEDS |
PORT SPEEDS 1, 2.5, 10Gbps |
PORT SPEEDS 1, 2.5, 10, 25, 100Gbps |
PORT SPEEDS 1, 10, 25, 100Gbps |
AVB SUPPORT |
AVB SUPPORT Yes* |
AVB SUPPORT Yes |
AVB SUPPORT No |
AV WEB UI / AV TEMPLATES |
AV WEB UI / AV TEMPLATES Yes |
AV WEB UI / AV TEMPLATES No |
AV DESIGN
AV DESIGN
AV DESIGN
AV DESIGN
- Dimensions (WxDxH) : 440 x 400 x 43.2 mm
- Weight : 6.31 kg (13.91lb)
- Primary Port Speed : 1 Gigabit
- Number of Ports : 48 (40x 1G PoE+, 8x SFP+)
- PoE Ports / Budget : 40 PoE+ (30W/port), 960W Budget
- IGMP Support : Enhanced (NETGEAR IGMP Plus™)
- Jumbo Frame Support : Yes, up to 12kb
- AVB Support : Yes. Electronic license required, activation key sent via email (AVB4248PX-10000S).
- Acoustics : Fanless or 59dB@25ºC
- Power Consumption : With PoE: 1197W/4086.56Btu/hr
- Without PoE: 89.2W/304.53Btu/hr
- Standby without any port connection: 74.5W/254.34Btu/hr
Third party support : Domotz
- Warranty: This product is backed by a NETGEAR ProSAFE ® Limited Lifetime Hardware Warranty . Phone and chat technical support provided for 90 days from purchase date. This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/registration within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
- M4250-40G8XF-PoE+ (GSM4248PX)
- Power cord(s)
- Console USB Type-C and RJ45-DB9 cables
- Rack-mounting standard brackets
- Longer brackets for recessed mounting
- Rubber footpads for tabletop installation
- Installation guide
