Easy Smart Managed Essentials Switch (GS308EP)
8-Port Gigabit Ethernet PoE+ Easy Smart Essentials Switch (62W)
The NETGEAR 8-Port Gigabit Ethernet PoE+ Easy Smart Switch delivers essential business networking features and powers PoE+ devices like VoIP phones, IP cameras, and more.
Gigabit Ethernet
8 ports provide up to 1000 Mbps of dedicated, non-blocking bandwidth each.PoE+ Support
8 PoE+ ports provide a total of 62W of power so you can power and connect your devices with a single wire.Advanced PoE Controls
Manage PoE prioritization, PoE power limit per port, and more for simple control over all PoE-powered devices.Non-Blocking Switching
10Gbps (10/100/1000 Mbps) line rate fabric ensures congestion-free connectivity to your devices.Fanless Design
Silent operation makes this switch perfect for noise-sensitive environments.Versatile Mounting Options
Install your switch on your desktop, or mount it to your wall or rack with the hardware provided in the box.Technical Specifications
- Dimensions (W x D x H) : 158 x 101 x 27 mm (6.2 x 4.0 x 1.1 in)
- Weight : 0.49 kg (1.08 lb)
- Speed : Gigabit
- Total PoE+ Ports : 8
- Total PoE+ Budget : 62W
- Uninterrupted PoE : Yes
- Bandwidth : 16Gbps
- Max Mac Entries : 4K
- Buffer Size : 192KB
- Energy Efficient Ethernet (IEEE 802.3az) : Yes
- Priority Queuing : WRR
- Jumbo Frame Support : 9,216 bytes
