M4350-24G4XF Fully Managed Switch (GSM4328)
24x1G PoE+ (648W base, up to 720W) and 4xSFP+ Managed Switch
- 24 Gigabit PoE+ ports with 4 10GBASE-X SFP+ uplinks
- 880W internal power supply providing 648W of PoE budget
- 1 slot for modular power supply (1+1 redundancy and/or EPS share)
- Any APS350Wv1, APS600Wv2, APS920Wv1, or APS2000Wv1 can be used
- The PoE budget can reach 720W, when the redundant PoE budget remains 648W
- Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover
- Layer 3 feature set includes static, policy-based, and dynamic routing
- NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
- NETGEAR ProSAFE® Limited Lifetime Hardware Warranty
- Lifetime Next Business Day Hardware Replacement
POWER AND
THROUGHPUT
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
FAST, EASY
CONFIGURATION
FOR AV PROS
FOCUS ON THE EVENT
NOT FAN NOISE
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
COMPARE M4350 SERIES SWITCHES
PRO AV FAMILY COMPARISON
M4250 SWITCH SERIES |
M4350 SWITCH SERIES |
M4500 SWITCH SERIES |
USE CASE |
USE CASE Access/Edge |
USE CASE Core/Access/Edge |
SWITCH STACKING |
SWITCH STACKING No |
SWITCH STACKING Yes |
SWITCH STACKING No (MLAG) |
PoE CAPABLE |
PoE CAPABLE Yes |
PoE CAPABLE Yes |
PoE CAPABLE No |
PORT SPEEDS |
PORT SPEEDS 1, 2.5, 10Gbps |
PORT SPEEDS 1, 2.5, 10, 25, 100Gbps |
PORT SPEEDS 1, 10, 25, 100Gbps |
AVB SUPPORT |
AVB SUPPORT Yes* |
AVB SUPPORT Yes |
AVB SUPPORT No |
AV WEB UI / AV TEMPLATES |
AV WEB UI / AV TEMPLATES Yes |
AV WEB UI / AV TEMPLATES No |
AV DESIGN
AV DESIGN
AV DESIGN
AV DESIGN
M4350-GSM4328 Technical Specifications
Product Specifications
M4350-24G4XF (GSM4328)1
Power cord(s)1
Console USB Type-C1
Rack-mounting standard bracket set1
Set of longer brackets for recessed mounting1
Rubber footpads for tabletop installation4
Installation guide1
Width440mm
Depth400mm
Height43.2mm
Weight6.41kg (14.13lb)
Primary Port Speed1 Gigabit
Number of Ports24 x 1G PoE+, 4 x 10G SFP+
PoE Ports / Budget24 PoE+ (30W/port), 648W Base, up to 720W Budget
IGMP SupportEnhanced (NETGEAR IGMP Plus™)
Jumbo Frame SupportYes, up to 12kb
AVB SupportYes, included
AcousticsQuiet Mode 33dB@25ºC
Power Consumption
With PoE: 792.1W/2701.06Btu/hr
Without PoE: 80W/251.2Btu/hr
Standby without any port connection: 32W/100.48Btu/hr
PSU Compatible Models
APS350Wv1
APS600Wv2
APS920Wv1
APS2000Wv1
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
This product is backed by a NETGEAR ProSAFE ® Limited Lifetime Hardware Warranty. Phone and chat technical support provided for 90 days from purchase date. This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/registration within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
Pro AV Information M4350-24G4XF Support
